Hydraulic Pressure Data Logging 3
HydroBuff
Industrial
Hi folks,
I am having a large amount of hydraulic pumps fail on a certain brand and model of equipment so I want to add a device to log and monitor pressure.
The machine has absolutely no HMI software or plc controls, so I am wondering if anyone would have any recommendations on some type of inexpensive pressure transducer that I could install on a a pressure line that would log data every time the machine spikes above a preset amount. Then later I could come back and view results. It would need to log for several weeks, or months at a time.
If any of you can suggest a device that meets the criteria above, I would appreciate it.
The pump should not be exposed to spikes when coming down.
I have seen this when the over hauling load is traveling fast and the valve is shut quickly.
Good data will help find what is wrong but one should record much more than just the pressure. Other things that might be important should be recorded too so it is easy to see a correlation. Recording the pressure is not enough. You only would know that a pressure spike occurred but not why.
On the data logger end, maybe the multimeter market has something for you. (googled peak capture data logger)
Fluke 287 True RMS Electronics Data Logging Multimeter with TrendCapture @ $760 (Amazon has it for $655)
https://www.fluke-direct.com/product/fluke-287-trms-electronics-logging-multimeter
- TrendCapture quickly graphically displays logged data session to quickly determine whether anomalies may have occurred
- Using on-board TrendCapture users can graphically review logged readings without needing a PC stores up to 15,000 recorded events
- Adjustable recording and auto hold thresholds, specify a percentage change in the readings that begins a new event
- Real time clock for automatic time stamping of saved readings
The definition of 'event' is up to whoever wrote the spec and the firmware. I would think an event is a triggered excursion above a defined level with a data acquisition period of x seconds. But what is an 'event' to whoever wrote the Fluke software?
On the pressure transmitter end: (googled fast response pressure transmitter)
1. Wika, 0-5000 psi, settling time <1mS (pg 7)
https://www.wika.com/media/Data-sheets/Pressure/Pressure-sensors/ds_pe8160_en_co.pdf
2. Omega, 0-350 bar; fast response < 1mS
https://assets.omega.com/pdf/test-a...ressure/pressure-transducers/PX409_Series.pdf
Thanks for bringing that up. There certainly must be more data. If you were in this scenario, what type of data would you be looking for?
Thanks @danw2 I will be sure to look into this.
Anything that would change the velocity. That requires acceleration and that requires force which requires pressure. Obstructions will cause this. Do you have an encoder on the motor, even a tachometer a would be good as long as it as be recorded. Instrumenting things can get expensive real fast.
Also be open to damage by operators abusing the equipment. Twice I've seen damage done by such abuse where ordinary use would never have a problem.
We had one where a hydraulically operated mechanism that is ordinarily used in a single operation for a few seconds (1 or 2) was reported to have developed a shudder. Various theories were put forward as possible causes, but what was concerning was the sudden increase in the observations across a number of different units that previously had not had the problem. It turned out that the operators were running the mechanism back and forth until they had exhausted the lubricant film to see if the mechanism was prone to shuddering, dozens and dozens of times, whatever it took.
Rocking, oscillating, dropping of large amounts of material, slamming the equipment into fixed obstacles. Note that a single operator can start this and get copy-catted or is training others to do so as well.
My two bit suggestion...
Try a USB6007 from NI (National Instruments). This is a device which is coupled to a 3-wire pressure transducer (either voltage or 4-20ma current mode) and the USB of a laptop with their data logging s/w (free with this purchase.). This is mainly a cheap Data-logging solution for student requirements. I am from India and the cost here is Rs42000.00 (i.e. about $500US). This does not include the Pressure transducer, which is extra.
Do you know, would the USB6007 log data for several days without being plugged into a laptop and then later I could connect to laptop and view logs?
In other words, I want to be able to log data for several days at a time, then view a graph of that later.
I'm sorry, like usual it looks like I didn't post enough of the pertinent details.
The main pressure relief is set at 3600 psi., but I expect that it may be spiking to more like 6000psi going by the types of failures we have had.
The budget? I hadn't thought of that yet.🙂Actually probably under $500.
The pumps are Parker tripple gear pumps on a pto from any random triaxle truck
The pump pressure is being used by Parker F130 valves to control various booms and other functions.
All the attachements are made by hose. I already have diagnostic quick connects in place. I can adapt or whatever to make any type of connection work.
Best Regards,
You can’t run gear pumps at 3600 psi, let alone spike it up to 6000. And I don’t need any data logger to know that.
Even 3500 psi on PGP 300 series are only rated for pumps with smaller displacements. PGP 600 series can go to 4500 intermittent, - but no way it’ll sustain 6000 psi spikes.
You’ve got to switch to piston pumps, high pressure at that, or run medium pressure pumps with added hydraulic accumulator.
Call National Instruments or go to their website. They will set you up.
