I am trying to remotely troubleshoot a situation that has come up with a hydraulic raise/lower system.
For safety purposes we require the raise and lower times to be within certain specs (Raise: 5.3-5.5 sec, Lower: 6.0-7.5 sec).
The latest times are too fast in both directions (4.5 raise, 5.2 lower).
The last time raise/lower times were measured was March 2002. Raise times were a little fast and lower times were barely within specs (4.9 raise, 6.0 lower)
I'm told that the only thing that has changed since March of 2002 was replacing a single plate orifice in the hydraulic line with a bi-directional multi orifice. My department was not involved in the design of this new "Bi Morf" orifice, but we are told that it did not change the raise/lower times when tested.
I think it is possible that this new orifice was installed backwards, or in the wrong location, but I'm told that isn't the case.
The explanation that I'm given for the change in times is that the cylinders have aged, and its a progressive thing that will get worse gradually. They plan to replace the cylinders ASAP, but can't right now and want me to waive the raise/lower requirements.
So my question, apart from asking for general comments on what I should do, is what generally happens to the performance a hydraulic cylinder as it ages?
