Hello All!
I am working on quoting a system to inject ammonia and/or hydrazine into a boiler makeup water line. The customer has specified that one of the pumps be dual use standby with a diverter valve before the pump relief valve. I'm having trouble finding anyone that is willing to quote a high pressure diverter valve for ammonia/hydrazine dual use. Fluid pressure is 1800 psi with 104 deg F max temperature. Anyone have any suggestions for a source for this valve? The information I have says 316 SS construction with PEEK or PTFE seals are good material choices. Thanks!
