Hydro on high pressure boilers
pvela
Industrial
Jun 21, 2019
Will be doing a hydro on our 800 HP boiler. Whats the best way to keep us from going to high when we do our test? Is there some kind of device we can use to keep pressure from going over set limit?.Thanks
Put a relief valve on the discharge of the hydro pump.
Quality is not an act, it is a habit - Aristotle
It's a serious safety task involving the ASME boiler and high pressure hydro testing.
Additional to the comments from this Forum, strongly suggest to have an experienced Expert help for the testing system setup, if you don't have an in house Maintenance to perform the test.
Thanks for the advise !! We will cover all our safety measures when doing our Hydro and we will have someone on hand for this testing. Thanks again!
