We know that hydrogen is now often described as an 'energy carrier' rather than as a 'fuel', since some source of energy is required to create the hydrogen in the first place.
One of the problems with hydrogen seems to be space needed to store it. I think we have all seen the pictures of vehicles with a fuel cell at one end, hydrogen tanks at the other, and not much in between.
I can therefore understand the logic of generating hydrogen in the vehicle rather than carrying the hydrogen around. However, if something like aluminium is going to be used as the source of power for a vehicle, why bother to generate hydrogen and then burn the hydrogen in a combustion engine or fuel cell.
When I first did some investigation to find out what fuel cells are, I didn't come across hydrogen fuel cells and automotive applications. Nowadays one has to sift through things to read anything else, but at the time, the information I found on fuel cells, was aluminium fuel cells to provide power to telephone exchanges in the event of failure of mains electric power.
I have a little digital clock at home. Two electrodes are plugged into a potato from the garden, an apple off the tree, or whatever else happens to be in season. It appears to many that the clock is powered by the apple. However, over time, the zinc on the zinc electrode [I assume that's what it is] is eaten away, and really the clock is running as a fuel cell with the fuel being the zinc electrode which will need replacing from time to time.
I would be surprised if creating hydrogen and then using it[/] proved to be more energy efficient than a fuel cell directly powered by aluminium, or magnesium, or whatever these guys decide to use as their fuel.
Last month the rage was the Russian scientists that have persuaded the UK government to part with some cash in the hope that spinning water inside a vehicle can generate the hydrogen required to power it - a sort of perpetual motion idea, as the hydrogen gets turned back into water!
Fuel cells are just batteries that don't get recharged. If I keep replacing the lead and sulphuric acid in a lead acid battery (and clearing out the waste, eg lead sulphate) then I have a lead and acid powered fuel cell.
Without any calculations to back it up, I intuitively feel that lead would be more effciently used this way, than somehow trying to generate hydrogen from it and then trying to use the hydrogen, and the same would apply to magnesium, aluminium, etc.
I'd need a good explanation to be convinced that what they are proposing has any real merit, but I'm a hydrogen sceptic anyway - at least until most houses are running off electricity from non-hydrocarbon sources.
