Vusal Quliyev
Dear HVAC Experts,
As you know there are some rules about hydronic heating systems routing(i.e. Fan Coil Unit system) in order to prevent air trap in the system which will lead heating capacity reduction.
I prepared one example and need your thought about this situation:
- High rise building.
- LTHW Fan Coil system for heating.
- Pipes enters to the level goes down connects to main pipe at corridor. Then pipe connection will be from up only until fan coil units. (See photo for information)
- We have Automatic Air Vent at the top of the shaft.
What do you think? Is there any risk of air trap in the system?
I wonder if there is any research or standard about this routing?
