We have a piping system designed under B31.3 (2", SCH 160, ASTM A106, Gr B, seamless, design pressure = 1370 psig, operating pressure = 1200 psig, hydrostatic test pressure 1.5 * design pressure = 2055 psig). The flanges selected for this system are 2" #600 ASTM A105, RF, SW, manufactured under code B16.5.
The QA-QC team say that the hydrostatic test pressure can not reach more than the value gives in ASME B16.5 - 2003, in this case 1480 psig. (table F2-1.1 working pressure for class 600 = 1480 psig @ 100°F)
But also, B16.5, para 2.6 System Hydrostatic testing says "Flanged joints and flanged fittings may be subjected to system hydrostatic tests at a pressure of 1.5 times the 38°C (100°F) rating rounded off to the next higher 1 bar (25 psi) increment. Testing at any higher pressure is the responsibility of the user, taking into account the requirements of the applicable code or regulation".
The questions are:
In your criteria, ¿which is the correct hydrostatic test pressure 2055 psig (according with B31.3), 1480 psig (working pressure for flages #600)?
¿Can we compare the value obtained from B16.5 para. 2.6 with the value from B31.3 to select the minor value of both?
I would appreciate your comments on this issue.
LV
The questions are:
LV
