jcat4
- Dec 14, 2010
- 11
Hi All,
What is your opinion on the use of water versus lubricating oil when performing a shell side hydrostatic test on a tube bundle (according to ASME BPVC Section VIII - Division 1)? We are mostly concerned with discovering leaks at the tube-to-tubesheet joints.
The fabrication of our tube bundle is nearing completion and our manufacturer recently advised that they prefer to perform the shell side hydrostatic pressure test with water instead of our specified lubricating oil. We initially stipulated the use of lubricating oil in our contract documents to ensure there would be no water contamination of the lubricating oil system once the tube bundle was placed in service. However, we are considering the possibility of allowing this change request.
I realize that ASME BPVC Section VIII - Division 1 indicates that "Any nonhazardous liquid at any temperature may be used for the hydrostatic test if below its boiling point." So, either water or lubricating oil seems to be acceptable.
However, are we making it "easier" for the manufacturer to pass the shell side hydrostatic test by using water instead of the lubricating oil? Or could a test with water be considered technically equivalent to a test with lubricating oil?
Any information would be greatly appreciated. If there is already a thread on this topic, then please provide the link. I tried using the search tool but could not find any relevant results.
