Hydrotest and Pressure Rating of 110m Tower 1
sshep
Chemical
Feb 3, 2003
761
Gentlemen,
I am a process engineer who has recieved a proposed design for a distillation tower 114.8m tall by 5.6m in diameter. By company standards, this vessel must be designed to be hydrotested in the vertical position. The proposed design pressure is 400kPa. I want 600kPa to reduce the relief requirements. The vessel will not be liquid full during relief.
Considering the vessel bottom has a field hydrotest pressure of 1660kPa at the bottom, there is plenty of shell metal thickness over all but the top 20 meters of the vessel to meet a 600kPa rating. Is there any way to get a 600kPa rating without adding shell thickness to the whole tower, and still meet ASME VIII D1 code requirements; and (if possible) the company vertical hydrotest specification?
Any help appreciated.
best wishes,
sshep
perhaps we should call this.."the highest above ground"..
there is one taller (actual height), but mostly below ground
