PipelineChic
Petroleum
Hi all!
I am reviewing some hydrotest data to confirm that the tests were acceptable and to sign off on the design. My concern is that the 600# flanges were tested to a max pressure of about 2300 psig in some instances, whereas the ASTM guidelines identify the max test pressure to be 2225 psig for 600# flanges.
I've read a few other threads on here and this degree of over pressuring does not seem to be a concern in real-life applications (since there were no leaks identified during the test)... but I need to be able to prove on paper, via codes & calcs, that this is acceptable.
So, question 1:
Am I missing something in the code that might specify 2225 as a loose suggestion instead of an absolute max?
2:
Is there a way I could calculate the actual 100% SMYS of an individual flange based on the actual properties (ex. grade of steel used) identified on the MTR's? Would it be calculated the same way as pipe (2*SMYS*WT/OD)? Or is there a different equation to use for flanges?
3:
I’ve identified the flanges as an issue, but are there any other fittings/components I should look into further that may have been over pressured (ex. valves, o-lets, plugs, etc.)??
(Note: pipe/flange sizes range from 1” to 30” in this system)
Thanks in advance for the help!
So, question 1:
2:
3:
