Good Morning,
I need to do hydraulic test pressure (Stress results) on heat exchanger in corroded condition.
In my case MAWP = Pdesign, but I can't activate in Compress the option to do the calculation in field corroded condition.
(I have 3 mm of corrosion allowance for each component of the equipment)
Does someone know how to do this verification with Compress?
Thank you
Thank you
