the Paper Owl
Howdy Everyone,
I had an interesting thought this afternoon after viewing an Australian documentary on architecture. The architect had placed a CMU block wall inside of the single story house (using primarily as an aesthetic feature) BUT rotated half of the blocks 90 degrees (along the x-axis) and created a checker pattern of open blocks within the wall system. Quite cool if you ask me (even if you were to simply have one or two of the top courses with an alternating design of standard block orientation / 90 degree block orientation).
Here comes the thoughts / discussion aspect as my mind began to wander. What if you were to detail a single family residence to have an internal CMU shear wall(s), for situations where such a design element would be overkill (the wall would be built similar to a shear wall tower in multistory wood apartment construction). I am aware of the inclusion of CMU walls for certain design aspects (I have used for a gun room / safe room prior in a house). My primary question is if a CMU shear wall(s) magically appeared within your design of a typical two story residence, how would you utilize it? I envision the wall becoming the basis of beam bearing / leveraged for strength by other assemblies within the house (My first thought would be to try and brace a majority of the roof assemblies / allow all purlin braces to bear on the wall as well). In regards to design and conveying a similar feeling to east coast row homes, having an internal "exterior" wall (much like the partition brick wall found in most Baltimore row homes that I have experienced) could break up the sea of drywall. Add a few 90 degree rotation oriented blocks within a few of the courses and now we're talking uniqueness in design.
I appreciate all that have read this blurb of thoughts and in summary wanted to discuss the possible benefits of having an interior CMU shear wall(s) within a lumber single family dwelling unit that would never have such an assembly BUT because of a collection of aesthetic benefits is now a part of the structural system.
Thank you in advance.
