HYSYS Simulation 1
choack
Chemical
Mar 11, 2012
54
I'm definitely new to HYSYS and other process simulation tools. I just have a question in HYSYS.. If I do want a sour water stripper with a caustic injection on it (this will entails having an equilibriun reaction between the NaOh and other components inside the stripper), should I still need to input reactions in the SIMULATION BASIS MANAGER or no need?
I will be using Sour Peng Robinson for my Fluid Package.
Any advise would be appreciated.
Thanks and Regards,
Christopher Kenneth Choa
HYSYS wont do reactions unless you tell it the stochimetrics and the equlibrium. I think you can do the reactions in the reactor if you use this.
Thanks MortenA for the reply. But I do want to clarify things. The reaction is a reversible reaction by double displacement only.
Should I still have a reactor even if I'm building a plant without reactor?
Many Thanks for the reply.
I'd check with Hysys technical support for an EOS recommendation, I don't think sour PR will do what you need it to do in terms of the caustic injection, pH and the effect on the stripping of H2S and/or ammonia.
Thanks TD2K,
I think I will add several reactions in the package environment first.
