I am in the process of investigating a cooling system problem in a 2000 KW diesel generator set. The generator set consumes belts in less than 150 hours. I have found a few issues that are problematic(drive undersized, poor sheave mounting, sheave to small). I can't however get the fan curve or any air requirements for the radiator from either supplier. I am being told that this data is not normally released to customers. Is this normal industy practice? Is there a good book that addresses industrial cooling systems and fan application?
