I work at a community college and doing some bending beam experiments for student labs. When doing simply supported beam deflection calculations and measurements, I am seeing some inconsistent data that I cannot explain.
If I test a basic cross sectional shape (square, rectangle, tube), I get very good results with theory. When I try to do an I-Beam however, the data is way off from theory...on the order of 50% more measured deflection that what have been predicted. Even if the area moment of Inertia between basic shape and I-beam are about the same.
I know the general theory says that stiffness should be proportional to 1/(EI). So why should I see a difference? My gut feel says that there is something different on how the load is transferred between the web and the flange that is not present in the basic shape. In other words, the strain may not be constant laterally across the cross section as basic theory would imply.
My background is Mechanical and my basic structural books do not address anything like this. I am hoping this is something addressed and understood by structural engineers. If you could help with some insight, it would be much appreciated. It always a little frustrating when you cannot explain unknown results to students.
