hi just wanted to know if there is a web site that has useful speeds and feeds tables for machining stainless steel , steel , aluminium and brass these are for use with both a vertical cnc mill and a cnc lathe max rpm 3000 on both . Bascially are machining department is going through alot of tooling and i think a few laminated charts reminding them of the speeds and feeds and if possible how deep a cut to take wouldn't go a miss . Both machines work in mm/ minute and rpm to it would be helpful if the charts were in this
thanks in advance for any response
cheers chris
cheers chris
