structengr23
- Feb 6, 2019
- 34
I have a typical chevron braced four level industrial structure that’s 10’ x 16’ base with four W12x65 columns. Supports a vertical vessel supported at the third level.
I’ve got a base plate with six bolts, three each outside the flanges. Since there’s a bolt at the center of the flange, I’m not able to grab the baseplate the the bottom of my gussets. My brace load is only about 20 kips, but I’m hung up with stopping my gusset above my anchor bolt. I modeled the work point one foot above the baseplate and ran my RISA model with this vertical offset and column is good. RISA connection is good with just a typical vertical brace connection, not connecting to the baseplate. Any reason to necessarily connect to the baseplate with a straddle type stiffened seat? Probably over thinking it.
