I have in my system nx 7.5 version
Pravidesign
3
I have in my system nx 7.5 version to official works ...at a same time I need to install nx 11....is it possible to install both nx 11...for nx 7.5 ugs license when I try to install nx 11 by splm license seriver it's asking upgrade or exit ...like that .is there any solution to install both license on different versions.
I assume it's still possible. When I was working (I retired in 2016), I always had at least seven or eight versions of NX running, all from a single license server (my laptop was set-up as a standalone system with it's own license server) so that I could verify issues when customers had an issue with some aspect of NX, covering at least the last several versions. Also, I was often asked to verify whether something really was able to be done using an older version of the software so I just keep as many versions on my laptop as I had space for (I had a big SSD drive). And yes, I often had multiple versions running simultaneously with no problems. You just had to make sure that the server was running the latest 'license sheet'.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thanks for your replay sir.... actually in nx 7.5 license was UGS license method. It's have a license of uglm_lic..like ..for nx 11 ...splm8 ... something it's came ...nx 7.5 already running ..need to activate nx 11 license for the previous lm tools application ... I want to know how to specify the path to the two different license in the previous like nx 7.5 lm tools .....
You can't have two license files in the same server/port
If your NX11 license is a updated version of your NX7.5 then one license is just enough.
The NX7.5 can run with a newer license server.
Gelson Z. Nicoletto
V.18-NX1980
