  • Congratulations 3DDave on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
I have purchased a topsoil screen with a 3 phase electric motor OLI MVE 1700/15N-60AO the screen is 2
Corbettdirt
Mining
Nov 27, 2020
6
Corbettdirt (Mining)
28 Nov 20 02:22
I would like to use my Generac 17500E 17500W/26250W Generator to power the 3 phase 460V (plug and play) HOW?
Brand: Paladin Industrial
Model: US70
Size: 4 Ft. x 5 Ft.
Screen Type: Square Mesh
Operation: With or Without Chutes
Features: Fork Pockets for easy transport. Removable partition plate outside the material outlet wall for easy separation.
Motor Brand: OLI
Series: MVE
Year/Serial: 202007 11529
MVE Type: 700/15N-60A0
Force kN: 17
Power kW: 0.75
Rpm/Min: 1800
Hz: 60
Amps: 2.16
Waterproof Socket: Type 114 / 16A-6 380-415V
Uses For Vibrating 2 deck Screen: Aggregate, Mining, Industrial and Recycling
itsmoked said:
I don't think I've seen a 'small' three phase generator under about 40kW.
If you have seen any of the older "MEP" military surplus sets such as the MEP-002A, MEP-017A(5kW),MEP003 (10kw) or MEP-016A (3kW), you have seen a small 3 phase generator set.
Huh. Hain't seen any that I recall. I owned a military generator and it weighed a ton and was built on a cast iron base. The generator body was 3 feet in diameter and about 2 feet long and the stator body was 1-1/4" thick steel, 4 cylinder water cooled, 1200RPM, and it was only 120Vac three something kW. It sure wasn't 3 phase. LOL.
Keith Cress
kcress -
