I-Joist Rafter Details Question.
XR250
5,952
As much as I dislike I-joists, I am stuck with them on this job. Looking for some feedback on this detail...
1) Does the connection between the double rafters seem reasonable? Not a lot of ply to ply load here, just a monster 28' span.
2) For the connection to the top plate, does anyone know how much uplift I can get out of the i-joist before the bottom flange fails?
3) For the perimeter band, does it seem reasonable to nail into the end of the flanges or should I use a filler block?
I have not shown the blocking between the joists over the wall.
Thanks!
got it - makes sense.
The connection does NOT seem reasonable to me but only because I thought that when load was applied from the side (and not from directly above) it was necessary to connect two I joists with web fillers (NOT thru the flanges).
Refer to the attached detail from one of the I joist makers.
 https://files.engineering.com/getfile.aspx?folder=59183401-8585-4b48-95c3-671b8db868cb&file=Screen_Shot_2022-03-12_at_7.42.35_AM.png
