PNachtwey
- Oct 9, 2004
- 778
A customer of mine is building a flying shear. He claims to need 37000 pounds force to cut the metal. This is achieved by using a 4 inch diameter hydraulic cylinder at 3000 psi. The shear itself weighs 2000 lbs. The shear has a stoke of 2 inches but it might be better to lift the shear just high enough to clear the sheet metal. The difference between the using the full stroke and barely clearing the sheet metal is that if one barely clears the sheet metal there will be no 'running start' at the sheet metal. If the shear is lifted 2 inches the shear may be able to build up some kinetic energy which should reduce the need for such high static force. Obviously one can cut metal by putting enough force along a narrow line. However, it seems to me that the kinetic energy would help too. If one takes into account kinetic energy wouldn't the need for such a high static force be reduced?
Can anybody point me a source that can be used to find the optimal trade off between static force and kinetic energy.
