I need to remove a rock without equipment 1
StevieRock
Mining
I need to find a way to remove a rock about 3 cubic feet in size and was wondering if anyone knew how to remove it.
Rent a rock splitter from the local contractor's rental center. Drill a hole and use the splitter to crack it into smaller pieces.
or
Dig a hole and bury it.
or
Rent an electric paving breaker at the local rental center and break it up.
or
Landscape around it in a garden.
or
Buy a masonry blade (diamond, carborundum, etc.) for a large circular saw or, preferably, a cut-off saw and make some cuts into the boulder which you can then use with the proper steel wedge and proper hammer.
Wear gloves, a dust mask, and eye protection as a minimum.
Also - advertise it. Someone might want it for decoration in front of his/her house!
[cheers]
the problem is that i cant use loud equipment so what would be the quietest.
If you can drill it, you could use expansive cement to split it up. The drilling would be the noisiest.
If no expense is to be spared you could a diamond coring machine to drill the holes before using the expansive cement.
The diamond coring machine is electric and uses water for lubricant.
Otherwise you could use a diamond wire cutter to cut the rock into any number of pieces. It is a bit like a wire cheese cutter and would be quite quiet. The russian submarine the Kursk was cut up with one although on a slightly larger scale!
StephenA
Hand-digging a hole and burying the rock is the quietest.
Except for the swearing and cursing when the rock falls on your toes!
StephenA
3 cubic feet is around 220 kg (at 2600 kg/m3 density).
Could you lift it by either getting a rope under the corners or drilling in a anchor bolt.
A tripod and chain hoist could then lift it.
StephenA
You could also use (rent?) a hand truck to wheel it away. The rock weighs about as much as a large refrigerator. Hand trucks are used to move refrigerators all the time. Wheel it to a pickup truck and get 3 friends to help you muscle it into the back of the truck. Or dig a hole and bury it. Three cubic feet is not a very large hole.
the thing is that the rock is half buried. Where can I get this expanding concrete and at what cost? I also want to know if i can use a normal hammer drill to make the holes for the concrete.
It is an expanding cement.
This web site answer describes three makes of expanding cement.
The one I was thinking of was Bristar, but not knowing where you are I do not know if it is available.
If the rock is half buried, how do you know that it is only 3cu ft and not bedrock?
A normal hammer drill (DIY type?) would drill holes but probably too small for the cement.
StephenA
