George631
Industrial
- Feb 16, 2009
- 3
I produce cabinetry and I am kind of new to Inventor.
Problem: I am able to reuse my custom I-parts panels in an assembly but I am UNABLE to have the lengths or widths of each part come through seperatly in the BOM with their respective parts. That is, I usually start with a panel thickness of 5/8" or 3/4" then modify the length, width, add features and so on as needed. But when I go to the Bill of Materials, all of the 5/8 or ¾ panels get lumped together. I get “Varies” under the length and width columns. I changed the names for each part as they are installed in the assembly, but get the same end result. I've got the parameters linked. I’ve tried modifying through excel sheet but can’t get the right formula. Can someone help?
