ahafeez3131
- Dec 16, 2011
- 12
In our power plant , at one location we have a ASTM A 106 pipe of size 1 ¼ , sch 80 is running. Water with a pressure of 1550 psig at a temperature of 550 F runs through it. During an inspection when the plant was in shut down state ( pipe having atmospheric conditions and filled with normal temperature water) an ICE PLUG was made on this pipe, with liquid Nitrogen. The liquid nitrogen boiling temperature was -197F. This plug was thawed after two hours. The metal pipe must have seen a temperature close to -197F, at normal temperature and pressure NTP or STP. Now we are moving back to plant start up.
My question is , does this -197F has any effect on the metallurgical properties of A-106 pipe. Does it made more brittle. How I relate MDMT ( minimum Design Metal Temperature) for this condition of NTP or STP.
A.Hafeez
A.Hafeez
