Identification of a part connected between the wheel and axle of a trailer
It would appear to be part of the braking system, either as a parking brake or normal brake. The rod will rotate and activate the brakes.
The complete lack of suspension seems a bit odd. I hope this is something like an agricultural trailer...
The spring appears to be the "return" (to the unloaded, un-braking" position) after the rod-and-shaft cylinder is pushed open by the hose.
I wonder if this is a jury-rig, when the original (internal brake-pad-cover) actuator died?
I don't think much of the axle to chassis connector....
@ LittleInch Yes, this is a picture taken from agricultural trailer. I have seen this system in all agricultural trailers. I was just wondering whether it was for braking system or suspension! I am still confused why agricultural trailers do not have suspension system!!
LittleInch is correct, it is the mechanism to move the brake shoe's to the "on" position when activated by the hydraulic cylinder and of again when the cylinder is deactivated. Simple but effective for an agricultural trailer and not all that different from what you would find on heavy motor vehicles. For your interest it is not "connected" to the wheel / axle - but will be suspended from the axle and supported by the backing plate forming part of the brake system.
Ag equipment does not use suspensions because it would cause more problems than it would help. Trailers would be more likely to tip over on a slope, and ride height changes with load. Tractors are basically equipment foundations with wheels. Plow depth could not be controlled if there is a suspension. Suspensions add cost and complexity, and provide no value at low speeds.
Its the brake actuating rod.
Thanx to all for your feedbacks. It's certainly a brake actuating rod.
