Identify a CATIA Component from a CATIA Product 1
Suncad
44
Hi there,
I'm working on a CATIA macro that need to check wether the current product is a real product (with its own .CATProduct file) or a component. The tree icon is different, so this must be stored somewhere...
ex :
for i = 1 to prod_count
if CurrentProd.Products.Item(i) <<is a product>> then
<<do stuffs>>
else
if CurrentProd.Products.Item(i) <<is a component>> then
<<do other stuffs>>
end if
end if
Thanks if you can help me,
Victor
Hi
Code:
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set products1 = product1.Products
For i = 1 To products1.Count
NameOfProdPart = products1.Item(i).ReferenceProduct.Parent.Name
If Right(NameOfProdPart,7) = "CATPart" Then
Msgbox "Part! " & NameOfProdPart
Elseif Right(NameOfProdPart,7) = "Product" Then
If NameOfProdPart = product1.Name & ".CATProduct" Then
Msgbox "Component! " & NameOfProdPart
Else
Msgbox "Product! " & NameOfProdPart
End If
End If
Next
End Sub
Fernando
- Romania
- EU
Thank you very much, I did'nt tought it would be that easy.
Try to use
sType = TypeName(products1.Item(i))
sType will be "Product", "Part", "Body", "Document", "Hybridbody", ...
Cheers,
Alex
