Identify type of component producing this noise? 1
buffoon1
3
Hi guys
I am not experienced in practical vibration/MCM but hoping to learn a bit from this interesting forum.
Could you advise what type of component is likely to be producing the intermittent "chirping" noise heard in the attached recording?
The machine is a portable home air-conditioner (the humble type with condenser exhaust pipe that vents out of an open window).
I suspect a failing bush or ball/roller bearing somewhere, but with minimal experience I wouldn't really know.
I will open up the machine and try to track down the component, but it would be helpful to go in a bit better informed.
Thanks in advance!
 https://files.engineering.com/getfile.aspx?folder=3323fd39-bbc4-42f9-945c-c864c556bfee&file=Bearing_failure_perhaps,_AC_unit.m4a
For anyone who is interested: In the end the condenser fan was clear, but two rows of the condenser coils were rubbing against a piece of expanded polystyrene that sits between the two rows. Jammed in some filter foam to snug things up. Seems to have done the trick.
