Identifying column marks on engineered drawing
Zoobie777
Chemical
Jun 28, 2022
12
I'm working on a floor and roof design for a 6-plex. The structural drawings are well laid out and there are good schedules for all the wooden beams,columns,joists,etc. However, there are a bunch of columns that are identified as either SC, S2C, S3C, 2S2C, or 2S3C. I am presuming these are steel. Does anyone know what sizes these might be? The wood ones are easy...C34 is a 3-ply 2x4...C46 is a 4-ply 2x6.
I tried the almighty google but got nothing.
Any help is appreciated. Thanks.
Those marks are no help without a legend or column schedule. They could be anything. Suggest you ask the designer for help.
Is it identified in a schedule? or are they marked up on plan. In earlier days, on the plan I would denote a column, say C1 as a W8x31, 1/2"x10"x10" B.Pl, 2 - 3/4" dia A.B, as Typ C1. Every other place on the plan where this column occurred would be denoted as C1 only. Is it noted somewhere on one of the plans?
It helps if you read the fine print. Found a note that explains it all. 2S2C means two studs and 2 cripples...that's a lot more detail than we normally get for window headers.
