Idler Shaft for Sundyne Pump LMV-311 1
walterdoub
Industrial
Nov 29, 2012
5
i am looking for an Idler Shaft for a Sundyne Pump. The Number is SH01AA03E, but it seems that nobody knows this number or the dimensons of this shaft.
Has anybody here an idea? Maybe someone around here is able to help me.
Which country are you based? Do you still need this?
I am based in Germany, and i still need some informations about these shaft. Do you know this one? Can you give me some dimensions, number of teeth?
Have you tried contacting Sundyne? I have had great response when I have contacted them directly. Not so impressive through some of their distributors.
I tried to contact Sundyne directly, but i still wait for an answer. And time is running out. If i know which Gears are mounted, it would help me.
walter..... i dont think most users on this forum are in a position to provide you information of specific OEM part numbers, unless they work for that OEM, in which case you would should contact the OEM directly. If they arent getting back...make more noise.
Good luck.
