.IDW veiw borders
aardvarkdw
542
when you move your cursor over a view in an idw, there is a red border that appears. Most of the time this border disapears after you move your cursor off of the veiw. When you click on the view, the border turns green.
Now, my problem is that that red border on one of my views will not disapear. I can select the veiw and it stays red. I can select a different veiw and the border on the other view stays red. I can print the drawing and the border gets printed. I can work in the drawing as normal but I can not get the border to go away! Is there a toggle that I am missing, or is there something that I did to cause this? I have had this problem once before and had no luck fixing it, but that was on a veiw that was easy to delete and remake. This is a base veiw and the part is pretty detailed. I would like to not have to redimension the whole thing.
Does anyone have any suggestions?
Do you have Service packs 1 & 2 installed and do you have a current video display driver?
As a matter of fact, we only have SP1 and I have no reason to believe we don't have a current video display driver.
