Imagelist
Creigbm
161
I am trying to find an exmple of how to create an Imagelist. I have been trying to figure out the syntax with no luck. Thanks in advance for any help.
Brian
Imagelist should be on your standard Control Toolbox toolbar. If the Control Toolbox toolbar is not visible, use View|Toolbars and check the appropriate box. Imagelist will appear in the standard list when you click on the ...More Controls icon.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
UK steam enthusiasts:
Thanks Johnwm. I got that far but was trying to figure out the coding (i.e. adding an image the list).
From VBHelp:
Set X = ImageList1.ListImages.Add(, , LoadPicture("icons\elements\moon05.ico"))
Good Luck
johnwm
