Dear All,
I have just started using ABAQUS and have less knowledge about it.
However, I have been given a task to work on a problem which includes the Finite Impact Analysis of a Charpy Impact Test. Basically the Charpy Impact Test is to be modeled using Abaqus and impact analysis is to be carried out.
Set-up of the Experiment
A Charpy Impact test is a destructive test used to determine the toughness of a material. Bascially the setup is such that, there is a specimen and a striker. The striker strikes the specimen at a certain velocity and fractures it. The fracture displacement is further on used to determine the toughness. I have also attached a pic below to explain the system.
However, I have modeled the Charpy test on Abaqus (as shown in the picture attached below). I have set the Material,Steps, Interaction, Loads, Mesh etc. and tried to submit the job. The job was not successfull and displayed an error saying:
"The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file."
Can Someone Please guide me through my steps and help me find the problem? I will be extremely grateful.
Thank you
Thank you
