Impact of compressed nitrogen entering a room 4
Coolman8
9
I would like to know what will be the temperature and relative humidity of a room when compressed nitrogen (72CMH) at an absolute pressure of 3 bar, 28 deg & -50deg C dew point entering it at atmospheric pressure.
Any help would be greatly appreciated.
What ever happened to Halon or its equivalent?? Only lowers oxygen by a percent or two - but still works quite well!!
Get with a manufacturer of these systems and they can guide you through the process...
Halon killed the ozone layer. Now we are all going to die.
why don't you think about "Inergen" ?
I am not a specialist in that matter but where ever I went in the plants I have been working in, the electrical rooms are all protected with an Inergen.
Before entering any of this rooms we turn a special key near the door that "inhibits" the Inergen system and shows in the control room an alarm (that means that someone entered the room and that the Inergen system is not working) coming out of the room anyone should turn the key in the previous position so the Inergen system is activated back!
drop a look at this link you'l find more about Inergen:
