Impact of volumetric shrinkage on prediction of viscosity of blends
blackmot
Petroleum
Aug 25, 2006
5
I am doing a study on viscosity blending requirements for heavy crude oil to pipeline specifications, using density control/feedback to the blending unit.
The prediction of the viscosity of crude oil blends using the Refutas equation usually works quite well, but in this case I am finding that the results of the blending predictions do not match my real life samples. The predicted viscosity is substantially lower than the measured blend viscosity in the lab.
I thought that perhaps this is an effect of volumetric shrinkage, because of the wide disparity on densities of the two products, over 1000 kg/m3 for the heavy crude and less than 700 kg/m3 for the diluent. The required dilution factor is on the order of 30 volume %. The shrinkage factor is about 5.5%. Does anyone know where I could find any information on the impact of shrinkage on viscosity blending prediction in crude oil?
