Cluain
- Dec 20, 2005
- 32
Can someone clarify UG 81 (f)(2) .
Is it requiring all test plates regardless whether the actual vessel needs heat treatment to be heat treated prior to charpy. Or, is it saying ( which is my interpretation) that if the manufacturer determines that the vessel needs heat treatment, then the test plates do also, with cooling rates and aggregate time etc.
Thanks in advance.
Thanks in advance.
