Import a part in a selected view..... 1
CAD2015
Computer
Jan 21, 2006
1,944
How could I bring/import a part (NX, for instance) in given view (top, for example)?
The picture in the right is an NX view of a part.
I want to import that part in AutoCAd but it comes as an ISO view......
Thank you!
You import the part. You get the part, not the orientation. It comes in as it was originally drawn. Once you have it, you can rotate it in Model space to the desired orientation or manipulate the viewport's UCS to show what you want.
If you are using XRef that is, you normall get whatever is in model space, which is why only the object goes in model space and not dimensions, titleblock, notes, etc
correct.
