Import Diagnostics 1
drawoh
8,959
I am on SolidWorks 2007 here. I have imported an assembly STEP file, and one of the parts is showing errors. According to the error window, I have six Check entity errors.
I cannot find anything that will provide more information on the errors. The Import Diagnostic window under Tools, is grayed out.
Does anybody know what I can do?
JHG
Do you have FeaturWorks? That may help you out.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
I think the errors have to be resolved before you can run featureworks. Is this a part within an assembly that has the errors? If so, you will have to open the individual part and try to run featureworks. Also, instead of using the tools>import diagnostics function, try right clicking on the surface or feature with the error and see if import diagnostics is listed and not greyed out.
Solidworks 2009 SP5.1
4GB Ram
Quadro FX3700
2.66GHz Core 2 Quad XP Pro SP2.0
drawoh,
Have you created any features after the import operation? If so, the import diagnostics will be unavailable. Even the creation of reference geometry will cause the diagnostics to be grayed out.
IIRC, you can roll back to just after the import feature and then perform diagnostics.
Try saving the part as parasolid and reimporting. You might just get lucky.
If not, can you post the file here? Maybe one of us can fix it with a newer version and post back as a good parasolid.
I think jobiewan is on the right track; you have to drill down through the feature tree of the imported item to the atomic level, and fix each primitive, then work back through the assemblies on the way up.
I used to import complete Diesel engines in STEP files. SW always had trouble with the helix that's part of the worm screw that's part of a hose clamp that's part of a hose assembly that's part of...
Mike Halloran
Pembroke Pines, FL, USA
A lot of mis-direction being suggested. Attach the original file here.
Here is offending file. I imported a STEP assembly file, and this was one of the parts. I have not modified it. I have FeatureWorks turned on.
All the menus that look they would help me are turned off.
Please note again that I am on SolidWorks 2007.
JHG
I'm running SW2011 so here's a parasolid.
There was an interference between the small rounded-square extrusions (at the back of the snap-in clips) and the circular enclosures. I moved the inner face of the enclosures out by .01mm and then saved as a parasolid.
Hope it will be good enough for your use.
 http://files.engineering.com/getfile.aspx?folder=c0aa012a-5082-4ee3-bf0e-b92d88e076cd&file=OPV6026_CONNECTOR_TYCO_5747840-5_-_CBL.x_t
CorBlimeyLimey,
It works!
Thank you.
JHG
