import txt file (that contains points)
pelle2005reg
Industrial
Jun 12, 2013
1
Hit o all,
in SolidEdge (i have the 19 version) there is a way to convert a txt file in a solid? The txt file contains some point that identify a surface or some surface.
Thank you
Hello there ,
You can use "curve by table" in Part environment /curves / keypoints .
But you have to copy your points into an excel file not a text file .
It will not create a surface only a curve , anyway is a good starting point for creating a surface with blue surf and so on.
nice day
