Important suspension parameters 3
GregLocock
Automotive
Apr 10, 2001
23,129
Orbiting a small yellow star
I'd like to compile a list of the suspension-related kinematic characteristics that need to be specified when designing a vehicle from scratch. By its nature this is a top down approach.
WHOLE VEHICLE:
Sprung mass
Sprung CG X and Z
Moments of inertia
Maximum steady state lateral acceleration
Ground clearance
roll stiffness (degrees per g of lat acc)
AXLE
position
track
tyre size, hence rolling radius
Jounce travel
rebound travel
track gain in roll
roll center height at design load
roll centre height gain
WHEEL
semitrack gain, ie lateral displacement of contact patch per unit of jounce travel
camber gain
toe gain
KPI
scrub radius
wheel offset
castor
castor gain
castor trail
unsprung mass
static camber
What have I missed? I realise some of these aren't kinematic, and some are interrelated.
Cheers
Greg Locock
Greg:
A couple of others that might fit into the list would be ride frequency, including front to rear percentages and lateral weight transfer percentage distribution front to rear. Another piece of the geometry would be steering axis angle. I am sure there are others
Dave
Torsional stiffness of the body structure
Stiffnes of the major suspension mounting points, ie on a McPherson Strut, do the strut towers move around
pat
Roll axis gradient and any gradient change relative to roll. Related to caster and caster trail would be pin lead/trail. What about desired Ackerman percentage/change, steering ratios and so on.
Ramon Mendoza
Hi Guys, I'm new to the forum- I just discovered it and it appears to be a good source of collabortion. I have worked in vehicle dynamics for the past 5-6 years doing both analysis (ADAMS and other smaller tools) as well as ride and handling development. Can't wait to talk with you all some more!
on to this topic:
Other compliance related parameters that are very important are:
Lateral force steer (deg/g)
Aligning torque steer (Nm/deg)- one of the largest contributors to the front cornering compliance after the tire cornering coeff.
Lateral force Camber compliance (small effect)
Aligning torque Camber compliance (small effect)
The other one I didn't see was TLLTD (tire lateral load tranfer distribution) or "roll couple distribution" which you guys all know is very important for limit understeer)
Ride Steer and Roll Steer
Ride Camber and Roll Camber
Side View Swing Arm Angle (SVSAA)
Lateral Stiffness (at ground w/o tire)
Fore-Aft Stiffness (at wheel center w/o tire)
Lateral Force Camber Compliance
Tractive Force Steer
Brake Force Steer
