Importing dxf files
sansvk
Aerospace
May 22, 2003
15
hi,
When I try to import a dxf file into UG 17, I get a message that says "scaling from mm to inch".
My drawings are in mm and I would like UG to import it in mm.
This face the same problem when i try to import it into a new or a work part.
I havent tried importing dxf into 18 or NX.
Please help me out.
Make sure the part your importing into was created with mm as the default unit of measure. Then do your import.
hai Sans ,
1.Create a new part file with the required units(mm).
2.Now import the file into the created file ,
regards,
Karthik
