I use RTV silicone rubber to make moulds for hard candy. Hard candy is basically boiled sugar that is poured into moulds at just under 300 degrees F. The castings of hard candy develop bubbles on the surface because the silicone does not dissipate the heat, unlike traditional metal moulds that dissipate the heat quickly. I've tried many different matrix formulations using silicone mixed with silica, and zinc oxide; results improve with silica but not enough to eliminate all bubbles. I know that thermal conductive silicone is used in various industrial applications, I just don't know how they are formulated.
