In Situ Particle Monitoring
BrunoPuntzJones
Materials
Oct 27, 2005
189
I work in vacuum coating, but not in the semiconductor industry. I'm hoping someone here may be able to help be out. I am looking for an in situ particle monitor for a vacumm system. The simplest of these system are a laser which traverses an opening. Particles pass through the opening and scatter the laser beam.
A bit of research shows that High Yield Technology (HYT) manufactured something exactly like what I want (HYT Model 10, Model 20, Model 25SX etc). But HYT has been bought so many times since then, I can't find information on who, if anyone stills makes that product. Inficon also makes a laser vacuum particle detector, called Stiletto. I have spoken with them about their system, but it's not exactly what I want, it is designed primarily to to go in pumping lines, I want a detect right in the chamber.
Are there other options out their I'm missing? What does the semiconductor industry use for in situ particle monitoring?
Thanks,
BrunoPuntzJones
IRstuff,
Thanks for the link. I will look into getting a used HYT particle counter. Do you know, are they not manufactured anymore?
I don't know; I've not been involved in semiconductors for more tha 20 yrs. You might query that recycledgoods company.
TTFN
FAQ731-376
FYI
Hach has stopped production of the HYT probes, but they are still supporting them. I have bought a used system, but I'd still be interested in hearing from people in semiconductor as too whether there is anything similar being made right now.
