kimseunghee
- Jul 12, 2007
- 35
Six step-down transformers(6.6kV/440V) are used for refregerator containers. These are fed from local power socket box via local power distiribution board. There is MCCB in the the local socket. This MCCB does not withstand estimated fault current.
As a measure, I am considering significant increase in impendace of transformer.
I am not sure if there is any limitation in increase or any side effect. I know ther is more voltage dip but When generator come on the line these containers are not engerzied because feeder breakers to TR is under volatge tripped. I should wsitch on after power restoration.
