jrexrode
Industrial
- Apr 16, 2007
- 6
Hi all. I'm hoping someone here can give me some guidance as I don't have a lot of experiencein working with gearboxes.
I have a 750:1 gearbox being driven by a 1HP motor connected to a VSD. The input HP as defined by the data tag is 1.38 HP. The motor runs at 10 Hz raising the load until it reaches its destination, but the drives faults out on overcurrent before the load reaches its destination. Can I safely replace the 1 HP motor and drive with a 2 HP motor and drive without damaging the gearbox? If this isn't an option, would changing the sprocket sizes to allow the motor to run a more optimum speed help?
