Indent function is not intuitive (to me)
PhoenixDynamometer
Industrial
Jan 6, 2011
97
Hello all,
After watching several videos, reading the help file and different blog posts, and trying this for 2 days I must admit defeat and ask for help. I am trying to do a simple indent feature with no luck. The part file is attached (SW2011 SP5.0). For your reference, it is a multibody part and "Imported1" is the target body and "Revolve2" is the tool body. I am trying to show hose ends in the received "crimped" format. Let me know what the hell I am missing here, thanks. [pc]
Home of the world's most accurate and repeatable dynamometers, dynamometer accessories, and data acquisition & control software.
See attached for an idea of what I am trying to achieve with the "Indent function". I would like to have the part with 2 configs (crimped & un-crimped).
Ahh, that's better.
First of all you have the Target Body & Tool Body reversed. The non-crimped part should be the target Body, and a surface (or solid) of the deformed portion of the crimped part should be created & used as the Tool Body. (Imagine wrapping clay on the outside of the crimped part to create the Tool)
You could also start with a flat sheet metal part and use the emboss feature, pattern emboss feature and then use the flex feature (bending) @360° and it will turn out to be a cylinder with a crimped look. Hope that helps. Cheers!
