I am building an offroad trailer and looking for alternatives to the standard leaf spring setup. The torsion axles have proved to be ineffective. I am looking into doing a trailing arm setup and looking for some sort of resource to start a design. Everything that I have found, mostly books for designing your own auto suspension, spend a paragraph denouncing the trailiing arm suspension and move on. The most prominat problem being flexing of the arm during lateral acceleration, not an issue on a trailer. Adventure Trailers in the US as well as several Australian manufacturers of offroad trailers build in this arangement and it seems to be universally praised.
If this wasn't going to be pulled down the highway, I would be more inclined to experiment, but is it as easy as it looks? A pin located beam with a spring/damper system locating a wheel hub? I can almost see that problem in an old text...
