Individual part drawings to multi-model drawing, easily? 4
fighterpilot
Military
Nov 5, 2004
381
I have an assembly with about 15 detail parts. Each part is an item in Teamcenter and each has it's own detail drawing in the file. The assembly also has it's own individual drawing.
Now, I'm being asked to take all those detail drawings which are standing alone and make them sheets under the assembly drawing. Essentially the assembly details would be on sheet 1, part 1 details on sheet 2, etc....
Since I've detailed everything already is there an easy way to take all that information and stick it as assembly drawing sheets? Or, do I need to start over and detail everything again? If so, how do I go about creating a multi-model drawing?
NX6
Thanks...
Fighter Pilot
Manufacturing Engineer
When the component count gets higher than what layers can handle, there are some games/tricks to be played.
One is to put components that have wide seperation between them on the same layer and then use manul view bounds to focus on each component in its view.
Another is to hide the component(s) in the view(s). This doesn't require you to use layers at all, but can be time consuming in a large assembly.
A combination of layers with ViV and hide components may be the best solution.
Ben Loosli
