coolbreeze
Greetings,
I am working on a project that will require a case hardened hollow shaft (100mmX77mm) The case depth will be about 5mm. Can I corrosion coat the shaft afterwards with a zinc phospate or Xylan coating successfully? I've just not tried this before and I am wondering if it will still work on on the surface hardened 4140/4340 steel alloy.
