Any idea why an engine manufacturer would specify a minimum exhaust backpressure on both NA and turbo'd models?
I need an exhaust system that will work for a wide variety of engines and outputs. The system needs to be large to keep the pressure below the maximum spec for the biggest engines but results in little backpressure (below manufacturer's specs) for the smallest engines.
