Inelastic beam analysis 2
LeonhardEuler
200
How is the shear found in inelastic analysis of continuous beams? I have checked several texts and have found the correct method to find the design moment using virtual-work, but can’t find an example of how to find shear. I know that shear is the derivative of the moment diagram, but what moment diagram should be used? If my failure mechanism is in a span that has an end fixed connection and the other support is an interior roller I essentially have a fixed fixed connection and if I have a distributed load the moment diagram will be a parabola in the plastic analysis method. I can then take the derivative of the parabola and divide by two and I have the shear on each support?
If anyone has a good example on this they could link that would be awesome
You know the end moments and you know the loading... shear should be a simple matter... Catch thread487-431213
Dik
For more complicated scenarios you could use a 2nd order inelastic analysis in a program like MASTAN2 to take out the guesswork. Free from [URL unfurl="true"]http://www.mastan2.com[/url], a very useful program. Check out the tutorials and stability fun section to get an idea of how to use it (it's not the most intuitive interface).
AISC places a limit on unbraced length in order to be allowed to use plastic design. If I have the following situation how would I treat the design?
* Span is 60 ft
* Lpd is 40 feet (limiting brace length for plastic design AISC)
* Top flange is continuously laterally braced
* Bottom Flange is only braced at supports
* Negative moment resulting in bottom flange being placed in compression only extends 8 ft from the support before switching to positive
Technically at a point the bottom flange becomes the compression flange, so in this scenario is my Lb 60 ft and I cannot use plastic design?
Just a single span? Not much advantage for plastic design, or, is it a portal frame? Can you use a parallel chord truss instead?
Dik
A point of inflection cannot be considered a braced point, so technically, at least one more brace would be required to use plastic design.
BA
